01-23-2024 12:11 PM
I just transferred my phoned number, porting team said it was successful. But when I try phone the number it said not on service. I tried to submit a ticket, but that never worked. I need technical support team, is there any way to contact to them? Thanks
01-23-2024 02:56 PM
Yes
01-23-2024 01:14 PM - edited 01-23-2024 01:14 PM
Please note that your old SIM will continue to work up to 2 hours. Once it stops working then power off the phone and swap the SIM and power back on.
01-23-2024 12:22 PM
@Guka wrote:I just transferred my phoned number, porting team said it was successful. But when I try phone the number it said not on service. I tried to submit a ticket, but that never worked. I need technical support team, is there any way to contact to them? Thanks
If the Public Mobile SIM card was inserted into the phone before porting had completed, a device restart is sometimes needed before the service will start working properly. Has that been done?
