No service with replacement sim card
12-13-2017 03:37 PM - edited 01-04-2022 03:06 PM
I had my phone stolen, so I got a new sim card. I changed my sim card number to the new one and I put it in my LG G3. It said emergency calls only. I put it in both my parent's phones and it said the same thing. I checked and my service is not suspended and my account is active. Why is my sim not working?
Phones
12-13-2017 04:12 PM
@justinxfan wrote:The phone is unlocked and it worked perfectly with my old sim card which was inserted on an LG G6.
Good.
Had that message twice yesterday; cured by rebooting the phone.
The other possibility is that the moderators will need to reset your account as suggested earlier.
12-13-2017 04:09 PM
12-13-2017 04:05 PM - edited 12-13-2017 04:06 PM
From where did you get the G3?
Are you sure all the phones are unlocked?
12-13-2017 04:03 PM
@justinxfan, I assume there were no error messages received when the new SIM card was added to your account. That being the case, I suggest sending a private message to the moderator team and have them investigate and correct the problem. The moderator team can be reached via private message using this link. Refer to the following link for information on contacting the moderator team.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
12-13-2017 04:02 PM
Could you have entered the sim number wrong?
You can always contact the mods and have them do it.
Contact the Moderator_Team by clicking here.
In your message include:
- account email address , pin number if possible
- PM phone number
- explanation of what is happening or a link to this thread
- if its a porting issue include your sim number, old account name and account number
