No service all of a sudden
bois3130
Been a PM customer for a couple years now with no issues and out the blue I have lost service. I've messaged the mods, but wondering if anyone else knew any tricks in the meantime that might fix.
iPhone 7, have hard reset and pulled SIM and replaced with a Koodo SIM which works fine.
8 REPLIES 8
bois3130
Turned out that the SIM card was defective. After replacing with a new one and having the Mod team switch everything over, everything works now.
It could be sim no lose contact with phone.
Do yo have other phone to test with, sim card might not work suddenly.
bois3130
Ya both SIMs are of the same locale and the PM SIM doesn't work in the other phone either. Is it possible the SIM is defective?
@MoreYummy wrote:
since everytyhing is update to date. and other sim is working, most likely its network issue.
Doubtful since Koodo works.  I would assume this test was done at the same locale.
will13am
Does the Public Mobile SIM card work on a different phone?
bois3130
Account status is active and I'm paid up until November.
ShawnC13
Have you logged into self serve to see what the status says on your account?  If it is active or suspended?
