No network
01-15-2020 06:30 PM - edited 01-05-2022 09:02 AM
01-15-2020 08:36 PM
Try restarting the phone. More information is needed to resolve this issue.
01-15-2020 08:36 PM
Please login to your account to check your status and try restarting your phone.
01-15-2020 06:57 PM
@123451975ira And as I always ask, whenever a similar topic appears, are you in an area with lousy signal strength? I ask, because my connection disappears quite often, due to garbage signal strength in this area.
01-15-2020 06:54 PM
Are you on autopay? Was you acount due? If it was, your autopay probably failed. Contact a moderator. Click on the green questionmark in the white circle at the bottom right of your screen . This connects to the autobot Simon. Type moderator and follow the prompts to get to one to submit a ticket.
01-15-2020 06:39 PM
Could you please login to your selfserve and check your status
01-15-2020 06:36 PM
Please remove your personal info from the public forum. Click on the 3 little dots to edit
Thanks
01-15-2020 06:36 PM
First please click the 3 dots on right side of your post and edit the post to delete your personal information (phone number)..as it's visible for the public to see.
Have you logged into your self serve account to see what the status of your account says?
Have you rebooted your phone?
