05-13-2018 11:08 AM - edited 01-05-2022 04:46 AM
My sim doesn't log on at public mobile network. I managed to enter my selfcare, where the sim is showed as active, just because the sim log on USA network(tmobile)!!![]()
So, as long as I am in canada, I can't use my sim!!!!!!
05-13-2018 10:54 PM
There's apparently multiple variants of the ASUS Zenfone 5. At least one is meant for EMEA and has radio hardware incompatible with North American networks.
https://www.gsmarena.com/asus_zenfone_5_ze620kl-9061.php
https://apn-canada.gishan.net/settings/854_3_telus_mobility_apn_settings_for_asus_zenfone_5.php
You can try this approach.
http://www.hardreset.info/devices/asus/asus-zenfone-5-lite/reset-network-settings/
https://www.verizonwireless.com/support/knowledge-base-214589/
05-13-2018 09:39 PM
@sciuritiddu, perhaps you should contact the moderator team (as recommended by @Luddite), and ask them to take a look at your account setup. Perhaps there is something wrong on their end.
05-13-2018 09:34 PM
no, I just used the connection to receive sms, and so be able to gain access to my selfcare page.
05-13-2018 08:49 PM
So you have a US roaming package right now? That is the only way you would be able to call and send texts using a connection to T-Mobile.
05-13-2018 08:43 PM
While I'm in Canada= no network, so no call/data
While I'm close to Usa border= t-mobile network, so I can make/receive call/sms
05-13-2018 05:36 PM
@sciuritiddu I'm confused by this thread; not sure what your reference to USA has to do with your difficulty. If you have activated a Public Mobile SIM and cannot receive service on an unlocked compatible phone, it would seem the activation failed.
Click this: message to moderators to send a private message to the moderator team with your SIM number, account email address, and an explanation. Moderator hours are: Monday - Friday 9AM (ET) - 9PM (ET); Saturday - Sunday 9AM (ET) - 7:30PM (ET). Response is generally within few hours, but may take 24.
No network usually means you have inserted an unactivated SIM.
05-13-2018 03:52 PM
Phone is unlocked, I'm not a Usa resident
05-13-2018 03:07 PM
@sciuritiddu Are you a US resident, trying to use your phone in Canada? Is your phone unlocked from your carrier?
05-13-2018 02:21 PM
I have tried with a windows phone and an asus zenfone 5. Public mobile network it's not showed even if I try to choose network manually
05-13-2018 02:04 PM
What phone are you using? Have you tried manually selecting the network?
05-13-2018 01:11 PM
@Anonymous wrote:@sciuritiddu, did you try restarting your phone?
Of course.I have also tryed with another phone and checked compatibility on public mobile website.
05-13-2018 11:18 AM
