No network connection BC
Dylan_Rogers
I can’t connect to my network? Tried resetting phone, checked carrier provider, tried resetting network still nothing
Meow
Check outages:
https://istheservicedowncanada.com/status/telus/map
TELUS Service Status
Do NOT start changing settings on your phone right away?!?!? WHY? If you did not mess up with it there is no reason to start changing it.
Try your SIM in another phone...
hairbag1
@Dylan_Rogers
working just fine in west Koot's.
will13am
@Dylan_Rogers , please check this outage site to see if you are in an impacted area?
https://www.telus.com/en/on/outages
slusagm
you have another phone to test the sim card?
and login My Account , does it shows account active?
