02-15-2022 12:43 PM
Phoene was working fine this.morning and all.of a sudden I can't make ir receive calls . I am.up to-date in payments, haven't changed the phone, Sim card is ok, I turned off and on the phone several.times, please help
02-15-2022 10:49 PM - edited 02-15-2022 10:50 PM
@scaredbunny wrote:Phoene was working fine this.morning and all.of a sudden I can't make ir receive calls . I am.up to-date in payments, haven't changed the phone, Sim card is ok, I turned off and on the phone several.times, please help
Can you log into your self serve account and ensure your status is Active?
While there, Remove your SIM card, and go to the Change Sim Card option under the My profile section and ensure the 4 digits listed there are the same last 4 digits on your actual SIM card.
If all good above, great.
After you reinserted your SIM Card did that trigger any services (which this action sometimes can).
Also, try your SIM into another compatible phone to see if services work then.
If still issues after all other suggestions, contact Customer support agents (CSA) to check on your account.
Two methods to reach them found here: https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
edit: one more thing...try manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings (temporarily) for dropping or unable to make incoming/outgoing calls.
02-15-2022 01:06 PM
02-15-2022 12:56 PM - edited 02-15-2022 12:57 PM
It could be cell tower has issues. I have no problems in Vaughan
02-15-2022 12:56 PM - edited 02-15-2022 12:56 PM
02-15-2022 12:46 PM
I live in Canada, haven't moved from.my home, network is not available
02-15-2022 12:44 PM
