08-16-2019 10:29 AM - edited 01-05-2022 06:27 AM
I used up my data.so I logged on with a computer and bought an add on. They have charged my credit card (as I have checked my credit card account) but I still have no internet and it doesn’t show on my phone public mobile account! I would say that it is theft.
08-16-2019 11:08 AM - edited 08-16-2019 11:09 AM
As others suggested, log into your account and check the payment history and see if the charge is displayed. Also check data and add ons - does it show the data add on that you just purchased or not?
Clear your browser's cache and restart your computer and log into your account again and see if it shows?
08-16-2019 11:00 AM
08-16-2019 10:58 AM
@Dirtgirl wrote:I did....twice
Add-on purchase is a two step process. Check your account to see if it has funds in it. If so, you did not complete step 2. If both steps are completed successfully, you will see the data add-on that you purchased in the overview tab. See this illustrated post of the two step add-on purchase.
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/m-p/198974
08-16-2019 10:39 AM
@Dirtgirl have you checked your self serve account to see if it has been added I don't believe you are getting ripped off it is a 2 step process as stated
08-16-2019 10:37 AM
Double check what RossN suggested, that after purchasing you applied the add-on To your account.
08-16-2019 10:33 AM
I did....twice
08-16-2019 10:32 AM - edited 08-16-2019 10:34 AM
@Dirtgirl I would say when you buy an add on its a 2 step process first you put the money in your account then you purchase the add on if it isnt showing up in your data add on section then you havent purchased it yet
08-16-2019 10:31 AM
Try restarting your phone.
