No internet connection
Michaelu112
I paid up my dues but i am not connected to the internet. I can make calls. What could be the problem?
TheGx
@Michaelu112 :Is your Internet still not working? You should follow up with this thread you created and let everyone know if you got everything fixed yet.
Hello @Michaelu112 ,
Try one or more of the below:
*turn off your phone, leave off for a few minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reboot your phone again
Are you just speaking of wifi internet OR data (with wifi disable or in non-wifi areas) as well?
HALIMACS
@Michaelu112
Below is a very good article which may assist:
(ignore #9 suggestion, you can avoid a factory reset...)
https://cellularnews.com/cellular-network/10-easy-fixes-for-mobile-data-not-working-on-android/
cellphoneuser1
@Michaelu112   Was renwal earlier this week?  There's a a glitch that makes data not reset after renewal.  Was the data working earlier?
JK8
Can you log into self service and look under My Data & Add-Ons to make sure data is listed. If it is not listed under there it has been used up.
Also is your mobile data on and your apn settings correct.
https://www.publicmobile.ca/en/bc/get-help/articles?q=Apn
