No internet connection
Ade12
Anyone else continually loosing internet connection until you restart you phone? I am having to restart my phone several times a day.
@Ade12
try to reseat the sim card. Power off, take sim out and wipe it  clean , them put it back and power up
Also, try Reset All Networks as well
And when it happens, check if voice calls work.  You might want to also manually set the network mode to 4G and 5G and test both networks (instead of leaving it on Automatic)
And try to change the network to manual and select Public Mobile from the list
Ade12
Samsung S23+, Victoria BC
@Ade12
what phone do you have?
did you try Reset All Networks? And which area you  are at??
Chalupa_Batman
Hey @Ade12
If you continue to have issues, you can reach out to a CS Agent and advise them as there may be a network issue.
