06-13-2026 03:55 PM
I have only used 7MB of data when my subscription allows 1GB and I have no data. My husband has the same problem. Two separate accounts.
06-14-2026 06:29 AM
I have the same problem did yours ever get fixed
06-13-2026 04:18 PM
@JaneJ1 wrote:I have only used 7MB of data when my subscription allows 1GB and I have no data. My husband has the same problem. Two separate accounts.
Hello @JaneJ1
There may be a very easy fix. Go into your settings and turn on Airplane Mode. Wait 1 minutes and then turn it off and reboot your phone. Do that to both. This will reconnect you to the Public Mobile network.
06-13-2026 04:00 PM
Check any outages in your area
telus.com/en/bc/outages
And make sure no data limit enabled on the phone. Reboot phone and Reset Network Settings
If that does not fix it, ask PM to check
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
