No data
Anthony80
I am able to make calls, but I have no data service... Data was working fine until yesterday. I have done all the basic fixes, still not working. Any suggestions?
Anthony80
Thank you. I got it figured out.
TheSterlinger
If you have checked that you have data and it’s not finished then, try turning on airplane mode then turning it back off. If a certain app isn’t getting data make sure it’s on for that app in settings (goes for android and iOS).
HI @Anthony80
maybe all data used up? Login My Account using Incognito/Private/Secret mode on your browser and check if there is any data left
Also, you tried you sim in another phone just in case it is  a phone problem?
and make sure you don't have Data limiter on, it could be the device's data limiter itself
