10-10-2023 06:38 PM - last edited on 10-10-2023 11:16 PM by computergeek541
I can't access any data on my phone these last few days. I've restarted it... my account and data usage are all in good standing. What might be the problem? I live in Whitehorse, Yukon and it doesn't sound like there are any outages here right now.
10-10-2023 09:23 PM - edited 10-10-2023 09:25 PM
Just reset the Cellular Network on your phone. It should fix the data issue.
If you are still having issues, contact a CS_Agent to look into your issue by private messaging them at:
10-10-2023 07:15 PM
Log onto self-serve and tap the little refresher icons to ensure you're viewing an up-to-date version of the data buckets.
Then try rebooting device and resetting network connections.
If possible, also perhaps try the SIM card (if physical, not e-SIM) in another device to see if data functions. This could be a device setting which needs amending or adjusting.
10-10-2023 06:47 PM - edited 10-10-2023 06:49 PM
