10-07-2019 12:40 PM - edited 01-05-2022 07:27 AM
I bought. A $10 public Mobile SIM card
I followed all the instructions and now my account is active. my new Motorola G6 play cell phone does not recognize that there is a SIM card or a network. I have been trying for 4 days now. I went to a kiosk where I bought my SIM card and they checked my phone and don't understand why it's not working. Apparently everything in my account is in order.
10-15-2019 11:28 AM
There was a technical inconsistency and the tech team addressed my issues. Now all is running smoothly.
10-07-2019 03:02 PM
Sounds like maybe there is an issue with the sim card.
10-07-2019 03:00 PM
@Lowufo wrote:Do you have another phone to try the sim card in to rule out it is the phone?
I don't believe it's my phone because my Telus SIM card from another phone works with my Motorola phone
10-07-2019 02:53 PM
10-07-2019 01:15 PM
Not recognizing that there is a SIM card in the phone is different than not being able to connect. Not recognizing the presence of a SIM card suggests phone hardware issue. Sometimes reseating the SIM card can alleviate the problem. Not being able to connect to the network suggests possible phone compatibility issues.
10-07-2019 12:45 PM
@Jvmah also if all else fails reset the phone to factory settings
10-07-2019 12:45 PM
Make sure your phone is unlocked and compatiable with PM. Did you check the willmyphonework.net website?
Try the lost/stolen feature. Log in to self-serve. Plan & Add-Ons from top menu. Lost/Stolen Phone from next menu. Suspend Service button. Log out. Wait a few minutes. Log back in and back to Lost/Stolen Phone and Resume Service this time. Log out. Restart phone. You could potentially lose any rewards that have. Also try adding a $1 payment.
10-07-2019 12:42 PM
@Jvmah wrote:I bought. A $10 public Mobile SIM card
Have you tried restarting your phoine? Resetting network? if that doesn't work try this,
Login to self serve - Plan & add-ons - Lost/Stolen phone - Suspend service.
Logout and wait a few minutes then login and select found phone.
This will not blacklist your phone.
