07-09-2017 02:19 AM - edited 01-04-2022 02:18 PM
I just ported my phone number and I am unable to send/receive texts, calls or use data. I paid a lot of money for this, and it's extremely frustating not being able to use my phone!! My phone was working fine, before this. I tried adding Public Mobile as an APN but that was of no use. I need to use my phone for work, so it would be very nice if someone could help me out asap!
07-10-2017 01:41 AM
@Shobi understood. Hopefully you hear back from a moderator fairly quickly.
07-10-2017 12:28 AM
Yes it's still an issue. I did restart my phone as well.
07-09-2017 01:40 PM
@Shobi is this still an issue? You had said you "just" ported. Hopefully you're aware that it can take a few hours. (Or, several days if porting in a landline or VoIP phone number.). I'm noping that was the case here and it's already resolved itself. If not, try a reboot to see if that helps. It's sometimes needed at the end of a port.
07-09-2017 08:25 AM
@S4u2875 wrote:Send private messge to MOD or try to msg on PM facebook pge, someone should fix quick.
The quickest path is private message. In all cases never submit the same thing multiple times. All that does is cause confusion for the moderators.
07-09-2017 06:49 AM
07-09-2017 02:32 AM
Sign into self serve and check the plan that was added and your available funds.
this thread might help
you will need to message a mod as well
To send a private message to the Moderator_Team click here
In your message send them:
1) account email address
2) PM phone number
3) explanation of what is happening
4) link to this thread if you want
07-09-2017 02:31 AM
Alright, thanks!
07-09-2017 02:30 AM
