05-16-2016 11:07 PM - edited 01-04-2022 02:40 PM
So I bought a new PM sim in the hopes of transferring to PM at the end of my billing cycle but it doesn't work. I have a Samsung Galaxy S3 that is working with my current carrier's sim card. When I insert the PM sim (and power cycle), the phone doesn't read it and shows No Sim Card, Insert Sim Card. I tried a suggestion I found on the forums, to add some backing to make the sim card as thick as the micro in my phone, but it didn't help. So any suggestions on fixing this? Or did I just get a bad sim and should order another?
Edit #1:
1. I have not yet bought a plan from PM, I inserted the sim to make sure it worked (and show no service because it's not activated).
2. My carrier is Koodo, and currently I have no other PM sim in the micro or changeable size, but I can check that tomorrow. However, Koodo told me that my phone is unlocked but I don't remember if I actively checked this; will do this tomorrow as well. Also, when I tested a locked S3 it shows Invalid Sim, not No Sim.
Edit #2:
But I've tested deactivated sims to check phone locks several times (not my phone; and they appear as detected and no service). Shouldn't deactivated sims behave the same as not activated sims?
Edit #3:
OK, so I finally activated my public mobile service and the sim is dead, still reads No SIM card - Emergency calls only. So what's my next step? I still need to transfer my number from Koodo before the final bill comes in but I need a working SIM to do that. And I need to do this in about a week.
Edit #4:
I tested the SIM* in a PM phone as well and it still displays No SIM inserted. So definitely I need a new SIM. Anyone know the turn around time for emails to PM?
Edit #5:
Yes, I activated the SIM before inserting it in my phone and left it in there for 20 minutes, incase it needed some time to read, no change in SIM status. (Also restarted my phones, both of the ones I tested).
Edit #6:
Solution: A new PM SIM Card that is NOT activated would simply state "Emergency calls only", and will not suggest or state messages like, "No SIM card" or "Insert SIM card". (At least that's how my new PM working SIM behaved in my phone). If the phone(s) are giving a "No SIM card" error or suggesting to "Insert SIM card" even when there is a SIM inserted, (2 phones of mine did), then the SIM card is not working, and a new one should be ordered. The exact messages will be different on different devices, but a working new PM SIM Card without activation will still work in the phone, it just won't provide service. Edit: All of the above is only true if the phone is properly working and unlocked or works with PM.
Service
05-27-2016 08:57 AM - edited 05-27-2016 09:48 AM
@Luddite @Shazia_K Sorry for not getting back sooner, but I thought I'd reply when I got my new SIM. This one works, and I replied back to the Customer Service with the information for porting my number as well, hopefully all goes well.
In a way I was right about the SIM card, because the new one works and doesn't state "No SIM card" or suggest to "Insert SIM" in the notifications.
05-23-2016 11:50 AM
Hey @Akudakatsu,
I'm sorry to see that you have been having issues with your PM SIM card.
As @Luddite mentioned, would it be possible for you to send me your current PM SIM card number and email address used for activation?
Please private message it to me and I will be glad to assist you further.
Thanks,
Shazia
05-23-2016 11:43 AM
I think it would be useful for a moderator to check your account as well. @Shazia_K @Mary_M?
In a pinch you can port your Koodo number before the SIM arrives since your account is active. The bad news of course is that you will have NO service until the new SIM is registered; except for a VOIP app, like Fongo, over wifi.
It seems odd that SIMs are failing.
05-22-2016 11:47 PM
@Luddite Sorry for the late reply, was planning on replying after the new SIM.
a) The account status states "Active".
b) Ordered another one, just hope it comes in time before I start another month with Koodo.
c) That phone and number is for someone else's use, and the SIM is full size (not triple) so I can't fit it into my phone.
d) Yes, my Koodo SIM is still operational.
05-20-2016 06:04 PM - edited 05-20-2016 07:37 PM
@Akudakatsu Some more thoughts:
a) When you log into your self serve account is the Status "Active"?
b) Go ahead and order another SIM card from PM?
c) You said you have access to a PM phone, so why not put its SIM into your phone?
d) Is the Koodo SIM still operating in your phone?
05-20-2016 05:13 PM
Okay thanks for the clarification!
Yeah in that case, it is probably worth trying a new SIM card like you said.
05-20-2016 04:29 PM
@saukalra Yes, I activated the SIM before inserting it in my phone and left it in there for 20 minutes, incase it needed some time to read, no change in SIM status. (Also restarted my phones (both of the ones I tested).
05-20-2016 04:22 PM - edited 05-20-2016 04:26 PM
Just to clarify, did you activate a PM plan on your SIM card before using it in your phone?
If there is an issue with the SIM, you can order another one. There is an option for next day delivery for a fee, otherwise the SIM will arrive in about 1 week. You can also tell us which city you are located in, and perhaps a community member would have a spare SIM that they can give you.
With regards to response to emails, they usually get back to you within 24-48 hrs from my experience.
05-20-2016 04:09 PM - edited 05-20-2016 04:12 PM
05-20-2016 03:57 PM
05-17-2016 09:49 PM
you are very welcome
keep us in touch,
regards
Jose
05-17-2016 09:42 PM
If the lack of activation is really the problem, then I'll do that soon and check everything out, and update this post. Thanks everyone for you help.
05-17-2016 11:40 AM
The network is as stable as Koodo since they are on the same towers, etc. "Outages" are usually related to account issues, particularly renewals that hang up. These are now being resolved within 24 hours.
Two step verifications that MUST use SMS could be an issue so you need a secondary that relies on the internet I think. Some of those will SMS to VOIP app such as fongo.com which is free, but some will not I understand. I regulary request application specific passwords that eliminate that issue unless I need to reset the account. I think some apps will accept email address as secondary verification.
05-17-2016 11:18 AM
@Luddite How often does PM go out? My only real problem is with having my number stuck in limbo because it is tied to two-step verifications. The other things like power outages and downtimes shouldn't affect me a great deal, as long as they don't last too long and hopefully don't happen when I need it to be active. xD
05-17-2016 11:01 AM
No charge for porting any number to PM.
I just put a unactivated PM SIM into my phone: "No SIM", "No Service Emergency Calls Only".
Without the SIM the messages are: "No SIM", "Emergency Calls Only".
Some additional detail here: Risk Free Activation - costs $10
If you must NEVER have an service outage suggest you read: SECURITY OF SERVICE
05-17-2016 10:39 AM
@littleburger I assumed that I could check whether the sim worked with my phone without it being activated because of something I read on the PM site/forums about buying a free sim and inserting it into the phone before buying a plan.
@Luddite My Koodo plan is active so hopefully that won't be a problem and I'm using a different email address here anyways. But I want to now is the phone number porting free after activation? I know some carriers charge for that if it's done after activation.
05-17-2016 08:56 AM
@Akudakatsu Your Koodo plan must be active in order to transfer your number to PM so I suggest you activate the PM SIM a week before Koodo expiry.
Also, there are have been difficulties moving from Koodo. Be sure that you use an email address different from that at Koodo when activating your PM account and activate initially with a temporary number. Initiate transfer once your PM account and service are active.
Koodo/Telus phones do not need to be unlocked to function on the PM network. PM data plans are not monthly but for the duration you select; 10, 30 or 90 days.
05-17-2016 12:40 AM
if you didn't activate and buy a plan, the sim card will not be working. Sim card will only work after actvation.
05-17-2016 12:16 AM
Okay, thanks everyone for the quick replies (really great community here). I'll check all the stuff tomorrow (can't do anything at the moment) and see what happens. The activation might have to wait (till the end of my current billing period). So I'll bump this then, or just post a thanks again. xD
05-17-2016 12:10 AM
No problem ..... you are welcome
Just need to remember ..... if you have not paid for the service, How can you expect service to be provided to you.....
Keep that in mind .....
05-17-2016 12:08 AM
Correct ........ to a point....
Will say the Phone has no SIM....... that is as far as you are right .....
But you can enter or bypass that and go into a cell phone as if no SIM is installed .....
You can still get to the menu, assuming that you know the assword too if the password is setup on the phone.
Then from the menu there are ways to unlock and that will a service cost to you from those that know how to un-lock the phone .......
Jose
05-17-2016 12:06 AM
@JVdSousa Thanks for the response regarding sim being not activated.
@Akudakatsu Like @JVdSousa mentioned, just inserting an unactivated sim card to check if it works does not yield you the result you have been expecting. You need to put in an active sim card that has been registered with PM. There's only one way to do this, you need to get a plan with PM and for it.
Alternatively, you can ask your friend in PM lend you their sim and you can put that sim in your S3 to test if your phone works.
Trust all these responses are pretty clear to you.
Let us know if you have further questions. This is PM family, we help each other.
05-17-2016 12:03 AM
@JVdSousa If phone is locked, then per my knowledge, one cannot get past Network Unlock screen asking you to input the unlock key. They wouldnt see No Sim Card message.
05-16-2016 11:51 PM
Hey Akudakatsu
Welcome to PM ........ great place to be ..........
05-16-2016 11:48 PM
05-16-2016 11:46 PM
But be certain that the CELL phone is NOT LOCKED with you previous carrier of your cell phone as well ....... or you need to UN-LOCK the phone or purchase another phone .......
05-16-2016 11:46 PM
You do not need to unlock your phone if you were using it with Koodo, since both Koodo and Public Mobile use the same network (Telus).
05-16-2016 11:44 PM
That is your problem .......
The SIM is just a SIM.........
You need to create an account and pay for the plan that of your choice ..... select what you want from the choices and type in the SIM number to the plan that you set up.......
You select a NEW phone number or you can chose to convert your old number from the other carrier to your NEW plan that is to be attache to that SIM...........
When you pay the FEE for the plan it takes about a day for the SIM to be activated .....
Only then will the SIM will work
Jose
05-16-2016 11:39 PM
So to add some information:
05-16-2016 11:32 PM
There is another issue as well that you may be looking at.
And that is, is your cell phone locked with you previous cell phone provider ?
If it is "LOCKED" then you need to un-lock the cell phone or purchase a NEW cell phone .
Did you previous cell phone provider supplied you with the phone on a contract ? If the answer is YES, then the cell phone is likely to be locked to them ...... that means that you can ojnly use the phone with them only. Unless you have the cell phone un-locked
Jose
