11-17-2017 08:52 PM - edited 01-04-2022 02:58 PM
Whenever I switch ON the 3G, I have no network on my phone.
I have recently switched to iphone5.
08-03-2018 10:41 AM
Well just switching the value to 4d4f works for now, had a couple of interruptions but I think it is because of the low signal in some rooms.
Thanks
08-03-2018 08:31 AM
@sheytoon wrote:The name shouldn't have any impact. It's not used by the network.
Yes, I know, but it's probably better to reset/remove the old settings instead of editing them.
08-03-2018 08:24 AM
08-03-2018 07:32 AM
@briareos477 wrote:Ironically, the site won't let me upload png type files.
Even the phone service cuts from time to time. This is basically what's on the page since I couldn't take the screenshot.
Name:
PC mobile
I see you have the name as "PC Mobile". Was that your previous cellular provider? Maybe try a full reset of your network settings and add the APN settings again.
08-03-2018 07:23 AM
Can you confirm data is enabled on the phone, and you can see some amount of data remaining in your online account?
A few things you can try for the APN:
Try changing MVNO value to 4D4F. If that doesn't work, try deleting MVNO Type (it will show None), and MVNO value as well (it will show Not set).
08-02-2018 11:49 PM
Name:
PC mobile
APN:
sp.mb.com
Proxy:
Not set
Port:
Not set
Username:
Not set
Password:
Not set
Server:
Not set
MMSC:
http://aliasredirect.net/proxy/mb/mmsc
MMS Proxy:
74.49.0.18
MMS port:
80
MCC:
302
MNC:
220
Authentication type:
Not set
APN type:
default,mms,supl
APN protocol:
IPv4
APN roaming protocol
IPv4
Apn enable/disable
Enabled
Bearer:
Unspecified
MVNO type:
GID
MVNO value:
50
08-02-2018 07:36 PM - edited 08-02-2018 07:37 PM
@briareos477, if you can make a voice call, you are using the 3G network.
Sounds like your problem is data not working?
Can you post a screenshot of your APN settings?
08-02-2018 05:27 PM
Hello I'm new to public movile, ive just switched from Telus, I have a Nexus 5 but I can't connect to the 3g network, I can call, I tried to look at the apn settings but they all seem ok
11-18-2017 02:51 PM
@NDesai wrote:May be no 3G bands available where you are?
You can check here: https://www.ertyu.org/steven_nikkel/cancellsites.html
3G coverage >> LTE coverage, always.
11-18-2017 02:45 PM - edited 11-18-2017 03:09 PM
@sheytoon Correct; one does not toggle 3G on/off, one turns LTE OFF! The phone is then restricted to 3G. That's my usual setting as 3G does seem more stable/available.
11-18-2017 12:16 PM - edited 11-18-2017 12:17 PM
That doesn't make sense. 3G is available essentially everywhere. Are you able to make any voice calls?
What do you mean by turn on 3G? I didn't think it was possible to toggle it on or off with an iPhone.
11-17-2017 09:10 PM
