No Service - Data or Phone
John8823
I set up a new account on a new phone yesterday and just realized that although my phone shows me connected to Public Mobile, I do not have a data connection and I can't place calls.
Please help
@CS_Agent
7 REPLIES 7
@John8823  They should reply with in the hour asking you some verification questions to start before helping you . Hope you get a quick reply 🙂
John8823
thanks, that worked to submit a ticket
@John8823  Use this direct link to support to submit ticket
John8823
As I said above, I've already followed PM's troubleshooting and did several reboots and resets.
But did you use the link provided above?
Also, try a full power off restart.
John8823
I've already followed PM's troubleshooting several times.
I've tried to submit a ticket 3 times but it always ends in an error message.
@John8823  reboot phone or reset network setting see if that helps if no luck please submit ticket with support to help
send a  private message   To CS_Agents click
