No Incoming Calls
Scherwinski
I switched from Bell a few weeks ago.  I said yes from Bell (porting) through the text message during the switching process.  I just realized that I am/have not received any incoming calls (They go straight to bell Voicemail) yet.
Your assistance to this matter would be appreciated!
2 REPLIES 2
Rando
Contact one of the mods and they will be able to look into the Porting Status on the back end and will be able to re-port it for you if required.
@Scherwinski the reply YES has to be completed within 90 mons, wonder if you missed the time
No worry, there is a nimber to call and talk to live support to confirm the porting status.   They will advise what to do from here.  I will message you the number,  please check your Community Inbox for the message
