10-24-2019 03:30 PM - edited 01-05-2022 07:43 AM
Hi
Just bought new phone One Plus 7 pro. Insered SIM card. It says connected to Public Mobile, I able to text but internet not working
06-26-2021 10:37 PM
OnePlus 8T would work perfectly on PM
I guess out of the couple Chinese phone companies, OnePlus has a better quality
OnePlus does have couple data breach before. OnePlus generally support 2 OS upgrades and 3 years of security patches for its flagships.
06-26-2021 10:24 PM
Hi, i've been thinking about upgrading from my S9+, to a one plus 8T. I wondered if they work on the public mobile network? Is the phone build quality similar to Samsung?
10-24-2019 04:23 PM
@harimoto wrote:it fixed. APN was on Telus for some reason. Changed to Public Moblile and it working now
@harimoto glad you figured it out. I had the same thing with OnePlus 7 (non-pro) (which I imported from AliExpress). I figured it was a quirk of my imported Chinese model (which was pre-flashed to the global OxygenOS ROM), because I've had two OP devices previously (OP5T and OP3), neither of which needed any manual intervention at all, they just picked up the PM network and worked. I guess OP must have changed something in the configuration of the newer devices.
10-24-2019 03:58 PM
The APN defaults to Telus on the SIM's data settings. You would have to manually modify it to PM's settings
10-24-2019
03:35 PM
11-04-2019
03:50 PM
Luddite
[Solution marked by Luddite]
