Newly activated subscription does not work with e-sim, need help cancelling + refunding
Kunkhen
same as title, device showed it was e-sim compatible through IMEI but failed to activate
slusagm
Check if the PM esim is installed already, check Settings ->cellular screen
Or check if  PM sent you a Welcome email.  there should be an esim QR code for you to scam and install
If you need PM to help, , since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
@Kunkhen wrote:
Thanks @Chalupa_Batman  It's an iPhone 16 plus brand new, let me try and trouble shoot before going through with this.
Hey @Kunkhen Oh for SURE it should work. Just wondering, is it an iPhone 16 Plus from North America? Sometimes folks have issues with foreign iPhones.
Kunkhen
Chalupa_Batman
Hello @Kunkhen
What phone do you have? If it did say it's eSIM compatible, it may just be an error and a CS Agent can help you resolve it.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
