New subscription not working
SarabjitM
I bought a new subscription on Jan 26. Payment was also completed and money is out from my account. I am unable to activate my number. Please help.
2 REPLIES 2
Moses_B
Customer Support Agent
@SarabjitM We apologize for the inconvenience, and our support team has sent a private message in case you still need assistance, please double-check your community inbox.
hi @SarabjitM
esim?  if so, can you double check if the PM  eSIM is already showing up on your Sim Manager or Settings-> Cellular?
if yes, then you need to manually enable it and set it as Primary (please also remove old carrier sim card and disable old carrier esim)
but if it is not there you will need to ask PM support agent to help, you can submit  ticket by direct message:
