New subscription not working
Camero
New subscription and phone # transfer not working after 2nd day after I paid and did everything please help me resolve this issue
1 REPLY 1
@Camero
it might or might not be porting related
try reboot phone once and test both outgoing calls and incoming
if you cannot even make outgoing calls, it is not a porting problem but a sim card provisioning issue, easy fix for PM support but please engage them by direct message here
If outgoing works but not incoming, then it is issue with porting, There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
