New plan signed up for changed after payment
Alanfind
Paid for unlimited canada calling was given unlimited B.C. calling . Upgraded to long distance for 8 dollars and now phone does not receive or call.
If chose and paid for a Canada-wide calling plan, but the activation system someone erroneously gave you a provincial calling plan, a moderator will need to make a repair to your account to get you on the proper plan.  I would also suggest that you ask for the long distance add-on to be refund, since it sounds like you may have only added it to try to get things working.
Luddite
If you ordered and paid for Canada wide calling, it seems the activation was not completed properly. Follow the earlier suggestion to contact the moderators. Be sure to request a refund/credit for the add-on unless you want it anyway.
pasvac
Please send a private message to @CS_Agent
Cat Tongue i'm not a moderator Smiley Tongue
GreatCanadian
Hi,
Did you go through the 2-step process when purchasing the add-on? First add the funds, and then make the purchase.
Did the phone work prior to the plan change? Purchasing an add-on should not affect the current plan.
You may need to private message the moderator team on this one, but you can try us here at the community first if you wish.
GC
