04-02-2019 03:12 PM - edited 01-05-2022 04:07 AM
I'm buying an unlocked phone that was with Public. Can I take the sim card out of my existing phone and put it in the new one and just continue on or is there more I need to do?
04-02-2019 03:38 PM
If the device hasn't been reset / wiped, I'd perform a factory reset first.
04-02-2019 03:32 PM
@Cheffy7 wrote:
As easy as just putting the sim I have in the new phone? No additional steps?
Yes, as long as the phone is unlocked and compatible with the telus network
04-02-2019 03:16 PM
04-02-2019 03:15 PM
Ok. Thanks
04-02-2019 03:13 PM
