New phone with existing sim card and plan
osama49
If I have already activated my SIM card, then I got a new phone, can I remove the sim card from the old phone and use it in the new phone? When I activated my sim card, I have given the old phone IMEI during the activation process.
Is there any steps I need to follow or do in order for the sim card to work on the new phone?
Thanks in advance.
osama49
Great, thanks
I have only been on PM for 3 weeks and both my wife and I have switched phones from our originals and I just put the sim in and it was good to go
osama49
Yes, new phone is unlocked.
Thanks.
ShawnC13
As long as your new phone is unlocked or locked to the Telus/koodo network you will be good to go.
