2 hours ago
an hour ago - last edited an hour ago
What is the reason for having 2 eSIM?
Yes, you can but you will have to create a new account on the second eSIM with another plan and different email address.
No, if you are thinking of have 2 eSIM on the same account. It will supersede the first one.
2 hours ago
HI @Ayabader
you can , but always just one active sim at a time and the latest one will be the one to use, all previous ones will be voided
So, you can buy a new PM esim but the old (current) one will not work after you got the new one.
