03-19-2023
03:42 PM
03-19-2023
03:45 PM
computergeek541
I'm trying to activate a new SIM and got Error 837
Joining Public
03-19-2023 03:44 PM
DO NOT try to re-attempt activation. PM might have charged you already.
Error 837 usually comes up when you request porting and used IMEI as the information for the old provider, or it could result from. problem on your credit card itself
First check if PM charge your credit card yet.
Also, put the PM SIM in a phone and check if it connects to PM network and if it can make outgoing calls
If PM has not charge you and the sim card is not connecting, then the activation didn't completed.
You can try to activate again and request porting, but try to enter the account number of the old provider instead of IMEI. Also, you might want to make sure credit card info entered correctly or try a different credit card instead
If PM has already charged you, then you need to open ticket with PM support and have them to sort out the activation and porting issue. Since you likely unable to login to My Account yet and open ticket, please open ticket by direct messaging PM support instead
