New activation
BAMD
I activated a new eSIM and account for my son. It took my payment but says expired. Nothing has worked
2 REPLIES 2
hi @BAMDyou will need to ask PM support to help
you can submit by direct message:
slusagm
Did you use the PM app to activate or just the browser ?
If you just used the browser z please download PM app to complete the setup
Or if you need PM to help,open ticket
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
