New SIM card
Chrisleggs67
I ordered a new SIM card but it has not been delivered.  Can I cancel the order and purchase one at a local Telus store
@Chrisleggs67
Hopefully it will arrive in a couple of days due the Labour Day holiday but suggest you contact a CS_Agent anyway.
Chrisleggs67
I placed the order on August 17
hairbag1
If you get a new sim at Telus or Koodo kiosk...save the PM sim that was sent to you. When it does arrive, you can gift it to a friend or family member. That way you'll benefit from the refer-a-friend Points program...plus you'll get a $10 credit to your account as long as they use your referral code when they get a PM account too.
Welcome to Public Mobile.
@Chrisleggs67
When did you place your order for the SIM?
Timer
@Chrisleggs67
yes you can by contact PM support team by private message > CS_Agent  with order #.
to Find TELUS Stores Near you  or  Koodo Stores  in person to buy it SIM card, and give a call to found out which store has it. some store sold out.
@Chrisleggs67 it usually takes 1 to 3 weeks for delivery.
I don't think you can cancel the order but you can message P. support and discuss
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
And yes, if you need one urgently,  pick up fromm Telus or Koodo store
