New Cusmtomer
MuAr2023
Hi There,
Is there a way to do get a public mobile number without having to get a number from another mobile provider and then transfer to Public?
Thanks,
MuAr2023
Thanks Much
dust2dust
Yes, they have a choice of picking  up a new number from here or transferring in.
Don't forget to use a referral code to get a $10 credit after signing up.
If you wish to use one from here then you need to ask for it first and then you'll see it in your messages.
Adding - slight edit
hairbag1
@MuAr2023
you can select a new number from the list available OR you can port in from old network. That's about it.
