New 4g plans
devbar74
Will the new 4g plans be able to connect to 4g only towers?
9 REPLIES 9
@devbar74
No voice calls on the LTE network as Public Mobile doesn't support VoLTE
devbar74
So I will be able to talk on 4g voice towers?
@devbar74 wrote:
Yes I know that. I am wondering if the new 4g plan will be able to connect to 4g voice towers.
Definitely...yes.
Viper33
in the same boat as you.  hopefully we can get some answers.
devbar74
Viper33
For the past few months all calls and signals complete are being dropped  on a very specific stretch along 427 / Gardiner highways in Toronto - our daily commute.  Chat agent said upgrading to the 4G plans would fix this problem which never existed in previous years.  Is there any information on this?
Kristowhy
PM service is all on the 4G LTE network.  The 3G plans are just throttled to 3Mbps up/down and the 4G plans are capped at 100Mbps up/down.  This is for mobile data.
For voice calls, presently PM uses the 3G HSPA network for this and your phone automatically switches to use that.
RossN
@devbar74 you needn't worry about that all towers should be able to handle your 4g
hairbag1
"4g only towers" ...not sure if there is such a critter right now. Your PM service is LTE...so you should be good.
