Network
Jeraden
Can't connect to network randomly today. Is there a outage?
2 REPLIES 2
@Jeraden  - if you do not see any outages in your area try some troubleshooting:
*turn off your phone, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*perform a reset network settings on your device
*try your SIM card into another compatible phone for a few days to see if the issues are the same...this could rule out a device issue/setting.
*manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings (temporarily) for dropping or unable to make incoming/outgoing calls
will13am
@Jeraden , you could check this outage map from time to time.  Select the applicable province.
https://www.telus.com/en/qc/outages
