Network
refugesailor
will your network in Canada support: GSM850/900/1800/1900MHz, 3G: WCDMA850/1900/2100MHz, 4G,5G
Nezgar
Yes the Public Mobile (Telus) network uses 3G/WCDMA 850/1900Mhz for calls or data, and various 4G LTE bands if your device supports that for data only. No 2G GSM or 5G.
PS: Wow @computergeek541 was quick to move this to a new topic. 🙂
GSM is not used at Public Mobile. If those are the listed specifications of a phone that you have, it will work at Public Mobile as Public Mobile uses WCDMA 850 and 1900 (band 5 and 2).
Jb456
@refugesailor
Public Mobile utilizes the following frequency bands:
4G LTE and LTE Advanced:
700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS)
HSPA:
850 MHz and 1900 MHz (UMTS)
