01-30-2020 01:24 PM - edited 01-05-2022 09:15 AM
01-30-2020 04:07 PM - edited 01-30-2020 04:08 PM
@Andiloveskyle wrote:My data isn't working in my phone and it keeps telling me to connect to public mobile network but won't let me i paid for a whole month of data I never got to use
Does the acutal message say something about needing to sign into the network? If so, that's the type of message that gets displayed if you either don't have data in your plan or if has already been used up.
01-30-2020 02:15 PM
Use these default settings
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Leave Blank
APN type: default,supl,mms,dun
01-30-2020 02:05 PM
@Andiloveskyle If all the solutions fail, contact a moderator and explain your problem . Click on the green questionmark in the white circle at the bottom right of your screen. This connects to the autobot Simon . Type moderator and follow the prompts to get to one (CLICK on account specific question and human and submit a ticket
01-30-2020 02:04 PM
Phone likely needs a reboot making sure data is enabled.
01-30-2020 02:03 PM
APN settings should be.
01-30-2020 02:00 PM
@Andiloveskyle Are you a new customer? Have you ever been connected to your data? If not you need to go to your network settings and see if you can connect to public mobile. If not you will have to set your APN to public mobiles.
01-30-2020 01:39 PM
@Andiloveskyle what's the brand and model of your phone? Is your data enabled? Try manually scanning for and selecting public mobile, and restart your phone.
01-30-2020 01:28 PM
Is your account active in self-service? Does it show data there? Did you restart your phone? Did you have such problem before?
