Network issue
Nasira123
My network is not working on my phone
Nasira123
I tried everything including restarting putting it in airplane mode
Also tried resetting network setting but nothing worked 😞
Julie93
The same thing happened to me (when I switched over to PM)
Go to your network settings in your phone and reset the network. Then you need to restart your phone. That should do it.
If not then you'll need to submit a ticket and get them to reset things on their end. Hope that helps!
@Nasira123
What troubleshooting have you tried?
Go to Settings and reset Network setting and see if that helps.
