02-21-2023 08:06 PM
Hi my network just stopped working and i did everything to get it tp work not sure whats going on
02-21-2023 09:20 PM
Hey @ZakirIsmail , check now. LTE service should be back now.
02-21-2023 08:54 PM
It appears that the LTE network is down but manually changing to 3G network will get your calls/text and slower 3G data working until they fix whatever is broken. Good luck!
02-21-2023 08:22 PM
@ZakirIsmail Can check here for PM outages.
02-21-2023 08:14 PM
@ZakirIsmail what exactly you have tried?
Check My Account for account status?
Reboot phone ?
Try to " Reset all network"?
Try your sim card on another phone?
Try your phone in another area?
did you check if your phone is blacklisted here:
https://www.devicecheck.ca/check-status-device-canada/
02-21-2023 08:11 PM
