Needing PUK code ASAP!
lamberguinixo
Hey, Ive never lock3e my SIM before but hey I thought it'd be wise, since donating my phones to wherever or whoever they end up with seems to be my trend.
HELP!  Haha. How do i go about acquiring the PUK code. Any help greatly appreciated. 😅
HALIMACS
@lamberguinixo
Click the little white bubble lower right.
Type "need PUK"
Follow precise instructions which are displayed.
@lamberguinixo
Reach to a CS_Agent to help with the PUK. They happily give the PUK by clicking on the envelope icon or Chat on this Community page.
@lamberguinixo
Find you PUK: https://www.publicmobile.ca/en/on/get-help/articles/where-to-find-your-puk
“SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.
"SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI (dial *#06# to get it) and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
“PIN unlock key (PUK)” is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
  • If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
  • Once the PUK is recovered and validated, you will be asked to choose a new PIN.
  • Only Public Mobile's Customer Support Agents (CSA) can give you this type of code, which the device manufacturer cannot. Public Mobile's Customer Support Agents (CSA) can be contacted at the following address: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
  • Caution! If the PUK is entered incorrectly ten times in a row, the SIM card becomes unusable.
