12-31-2022 08:14 PM
Hello! I’m in the US and need to add more data - but have already bought all the available amounts (1gb, 500, 250) - and now none are available to purchase. Please help!
12-31-2022 08:29 PM
@zrussell did you try to use Incognito mode to access My Account?
And if you already bought the the data and you need to repurchase before the 10 days expiry , you will need PM Support's help to re-buy of that.
12-31-2022 08:22 PM
You should contact support staff, @zrussell
12-31-2022 08:17 PM - edited 12-31-2022 08:23 PM
One will have to totally expire before you can add another. Are you sure you added a US add on and not something else?
12-31-2022 08:16 PM - edited 12-31-2022 08:20 PM
You'll have to get help with that from a Customer Support Agent, if you're trying to get the exact same one.
Use the Chat Bot Simon to get a service ticket started first.
The link is at the bottom of this page.
If you have trouble getting a service ticket started, you can also send a private message to CS_Agent for help with that too.
