10-19-2022 04:48 PM
In order to receive calls and texts on a transferred number, we need a new Port Out Request sent. How can we get that so my son's plan will be fully active? I need to know when the request is happening as the account with Lucky no longer has funds on it so I will need to call them within an hour of the Port out Request from Public
10-19-2022 04:54 PM - edited 10-19-2022 04:56 PM
Does your son still have the Lucky sim? If so put it back in a phone and then call the number in the link to re-trigger the port.
Then you will get a text to confirm. Then the old account will close. Restart the phone with the Public sim in.
Adding - hmm is the other user right? Are you leaving Public or coming to Public?
10-19-2022 04:52 PM - edited 10-19-2022 04:54 PM
Both accounts have to active. Assuming you are porting to PM? Your wording is confusing so please clarify - port to where???
You initiate port out at Lucky side. Port authorization SMS should arrive very quickly thus keep Lucky SIM in a phone. Reply Yes within 90 minutes.
If you miss that 90 min window you have to go back to Lucky to send port authorization request.
