08-11-2024
07:30 PM
08-11-2024
10:46 PM
computergeek541
I registered the eSIM on the wrong phone and deleted it, then couldn't use it on the correct phone. The transfer semi went through as when I try to log in it is asking to send a code to the transferred phone number which cannot receive texts so I cannot access the app to get a new eSIM. I need a new eSIM
08-11-2024 07:42 PM
Hey @Joannetheoret
You should see an option that says.. Didn't get Code?? Then click on it and you should see "Send to email"
08-11-2024 07:42 PM
send a private message to CSA o they can look into this
08-11-2024 07:35 PM
Eversafe wants to send a 6 digit code to the confirm the account. They send via text to the correct phone which doesn't have texting because it's half transferred. Cannot access app
08-11-2024 07:33 PM
You need open the app on the right phone, and buy a new eSIM, it should be free $5 - $5 = free
