Need help
Jennkudlak
How can I get my data working on my new phone?
popping
If you have a LG phone, do a network reset + restart your phone after changing provider before the data working again.
Always do the simple thing first:  Enable data and restart your phone to let PM SIM to initialize your APN setting before manually update your APN setting.
Lemony_Snicket
@Jennkudlak , what model of phone do you have. Does talk and text work?  Likely you need to update your APN settings.  Use the help pages on how to.  It's pretty easy and helpful.  I typed APN and got this.  Good luck.
https://www.publicmobile.ca/en/ab/get-help/articles/set-up-data-on-an-android-phone
Triguy
Make sure you configure the PM APN settings.
https://apn-canada.gishan.net/en/apn/public-mobile
