Need help
Cameron13Latta
I have been with Public for a month and can receive texts from Android/Samsung users on my iPhone , but can’t send them. I didn’t change any settings from my previous supplier and could send texts. Does anyone know how I can fix this?
@CS_Agent
CSA_PM
Customer Support Agent
Hello @ Cameron13Latta,
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
Cameron13Latta
@CS_Agent
My iPhone receives texts from Android, but won’t send them. Help? I have checked basic settings but not sure what now.
Cameron13Latta
Yes, it’s on. I tried turning off and but no change.
Cameron13Latta
It was already on, but I toggled it off and on and still won’t work. I don’t really want to reset. I thought I tagged a CS rep, but no reply. Do you know how to do it?
Dunkman
@Cameron13Latta
Might want to check your settings. Turn on RCS messaging (for Android users) on your iPhone.
Can also try network reset of phone (note: this will erase any saved Wifi passwords).
SKSuh
Do you have “send as text messages” enabled on your iPhone (within the Messages app settings) ?
