Need help
Kylesg
I’m going in circles. My 2mfa is asking me for 2 numbers. The second is the new number that isn’t getting sms. I deleted the eSIM and need a new one but can’t get in to do anything !!
Dunkman
@Kylesg
You should be able to get 2FA code via email instead.
Do you see the options "Didn't receive code" ?  Click on link and it should offer 2FA email instead.
Kylesg
Just did. Thanks. Fingers crossed they can remove the second phone number so I can sign In.
@Kylesg try using a different browser
Or just start a new message and type CS_Agent in to To field
Kylesg
I thought of most of that. It’s not allowing me leave a message ?  
slusagm
@Kylesg if you click Didnt Receive Code, is there Send email or voice message option? If there is such option, go to Account page in the app and buy esim
If not, you will need to ask PM to help. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
Chalupa_Batman
To get a new eSIM, you're going to have to reach out to a CS Agent.
The Public Mobile chatbot is currently unable to create trackable tickets for members who are unable to log in. So for this reason, please use the following link to contact them.
