02-06-2024 11:47 AM
Hi, I am having troubles setting up subscription. It says "Selected plan not available The postal code on your card doesn't match the province you selected. Please choose another plan."
I am located in AB so I am not sure why it is not allowing me to choose the correct postal code/plan.
02-06-2024 12:12 PM
@LOJ , this seems to be a common problem as you are not the first to report this issue. Please reach out to support using the link below and they can assist with your plan selection.
02-06-2024 11:54 AM
HI @LOJ
this has been a common issue. Which province you are at?
did you try to use the PM app to subscribe?
02-06-2024 11:51 AM
To prevent unauthorized credit card usage, I'm pretty sure the registered postal code on the credit card needs to match the registered area code location.
