Need help with data
LorenzoKaufman
Hello need to discuss data.
thank you.
1 REPLY 1
hi @LorenzoKaufman
what is the issue? you have no data at all?
if so, make sure you turn on Data, make sure you disable Data limit on the phone
then Reboot phone and click Reset network settings
