Need help to trigger the port request
cdvfbg
Hi there, can you please help trigger the port request? I haven't received port request message so far. Thank you
8 REPLIES 8
cdvfbg
Thank you for the reply @slusagm
hi @cdvfbg
the number we provide is a good number.  It is Koodo but the team helps PM porting issue. Problem is some new agent might not know that they need to help PM and they simply refuse to help
 i suggest you to call again now before it is closed , and maybe tomorrow morning and hope another agents pick up
cdvfbg
Thank you for clarifying @slusagm
cdvfbg
Can someone help as no one is replying to CS_agent and the number provided is not helpful in my case. It is frustating to get no response or to get the default reponse which is same everytime when I ask for help
we are just customers here in the Community
you have done the right thing to ask for further help from CS_agent.  Message them again
but it might be closed now, so likely you will have to work with them tomorrow morning
cdvfbg
I have already submitted the porting request more than 2 hrs ago to CS_agent.  Calling the number doesn't help either. Can you please take a look? Thank you
slusagm
not sure if you are porting out or poring in
if you are porting in, there is a porting assistance team you can call and ask for update.  I can't post the number here, but I will message the number to your community inbox.  Please check and call them
but if you are porting out, you will have to contact your new provider and ask them to resend porting request.  But if you still don't get the message, then ask PM.   Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA  code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.)    When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox,  between 9AM-10PM EST (Mon-Sun), check here:
hi @cdvfbg
PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway),  you can submit  ticket by direct message:
