04-08-2024
12:53 AM
04-08-2024
12:58 AM
computergeek541
Missed texting for transfer request and now having trouble in receiving calls and texts msgs so now not able use SIM card properly. need help to fix the issue and initiate the transfer request again.
04-08-2024 12:59 AM
@Anmol2 wrote:Missed texting for transfer request and now having trouble in receiving calls and texts msgs so now not able use SIM card properly. need help to fix the issue and initiate the transfer request again.
Please use the chatbot to open a ticket and ask ask a Public Mobile customer support agent for help. https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Inside the Public Mobiel app, there is also a support section that can be used to submit a ticket.
04-08-2024 12:58 AM
Check email icon. I will pm you the number to.
