04-04-2017 08:50 AM - edited 01-05-2022 01:54 AM
Hi guys,
Just bought a Android phone and I guess I need to set up APN so that to receive picture message. Could someone guide me please?
Thanks.
04-04-2017 05:36 PM
and don't forget to reboot the phone after!
04-04-2017 10:54 AM
Be sure you have cellular data turned on.
Here are MMS settings from @s2scotty
If you have multiple APNs listed, ONLY one, the PM one, should have the APN type "default".
Including "mms", as in, "default,mms" makes it clear TO THE PHONE to route MMS via this APN/carrier. IT APPEARS CRITICAL THAT there are NO SPACES between the words and the commas (e.g. "default,<space>mms" = wrong and "default,mms" = correct). A trailing space proved an issue on a phone (e.g. "default, mms<space>" = wrong and "default,mms" = correct). Like "default", only the correct and active APN should include the "mms" tag.
* Name: Mobile Internet
APN: sp.mb.com
Proxy: Unspecified
Port: Unspecified
Username: Unspecified
Password: Unspecified
Server: Unspecified
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Unspecified
* APN type: default,mms
* APN roaming Protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
04-04-2017 10:46 AM
@Yosief, here is a great site that has the APN settings. You will just put in your Make of phone, Model and then the network you are on and it will come up with the settings you need.
https://apn-canada.gishan.net/
04-04-2017 08:58 AM
@Yosief Since you're new just wanted to give you the heads up that often times a search through the forums will often provide hte answer you are looking for.
Granted the community is here to help if you need it, but if you're ever in a hurry it can be quicker to search.
04-04-2017 08:52 AM
Step-by-step APN configuration
Lithium-OrangeBullet-Jan23-00.jpgStep1:
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Click here for Android APN Screen Shot
Blackberry
OS 10 - Settings > Network and Connections > Mobile Network > Tap the settings icon (dented wheel)
Windows
Windows 8 Step 1 Settings > cellular > Add or Edit internet APN
iPhone
Click here
Lithium-OrangeBullet-Jan23-00.jpgStep 2:
You will need to input the following information:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
Lithium-OrangeBullet-Jan23-00.jpgStep 3:
Select Save/Done. Select Public Mobile to connect to the Public Mobile network.
