05-02-2024
04:06 AM
05-02-2024
08:34 AM
computergeek541
05-03-2024 05:29 PM
Thanks everyone who helped me out to try and figure out what was going on with my account come to find out i couldn’t use the eSIM (but I had one like 2 weeks ago from public mobile and then my account got locked out for no reason ) I guess my phone now will not work with the eSIM so I had to drive 53 mins to town and go and buy a sim thanks everyone have a great rest of your day
05-03-2024 12:37 PM
I submitted a ticket and they asked me for my number and my email so sent that to them and I’m just waiting now so I hope they come back soon thanks
05-03-2024 01:27 AM - edited 05-03-2024 01:32 AM
HI @JustinE88
are you on iPhone? if so, you need to check the Settings > Cellular screen and see if Public Mobile eSIM has "Turn on this line" enabled
if you still unable to make the esim work, please message support agent
Also, for your privacy, I have removed the image from the post. Please go to your Image Library: https://productioncommunity.publicmobile.ca/t5/media/gallerypage/user-id/413351/tab/all and delete your image there. Hover the mouse to the top right corner of the image and click X to delete it
05-03-2024
01:20 AM
05-03-2024
01:25 AM
It does show it but then it says this when I go in to my phone settings please someone help me
Update by Softech: remove image for privacy
05-03-2024 01:08 AM
as said above, this is how to message support for help
But did you check your Sim Manager or Settings>Cellular screen to see any chance the Public Mobile esim is there and just not enabled properly?
05-03-2024 01:06 AM
So when it is activating the sims to goes till it it almost done then says sorry cannot active eSIM and to contact customer support but I can’t find where to do that
05-02-2024 07:56 AM
iphone or Android?
Did you get to the eSIM installation step? Either the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone.
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone, disable those non PM sim (eSIM/Physical sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, Please open ticket with PM support:
05-02-2024 06:48 AM
Please follow through this link for details on E Sims:
https://www.publicmobile.ca/en/ns/get-help/articles/esim-faqs
